I tore up a perfectly good mad light today to make a bigger catch can. it s a 4 d side light. pics explain it. all you need is:
--the 2 pvc gromets (part #'s included in pic)
--the pvc valve (part # included)
--some copper (or stainless) emery cloth
--i used a 3/8 elbow at the light and a 3/8 to 3/8 coupler at the valve cover (where the pvc normaly is)
Note that the light is airtight but I didn't want it to see boost all the time and thats why i put the pvc valve at the the top of the light instead of at the valve cover where it normaly goes. for the pvs gromet going through the lens you must first drill a 1" hole in the lens. note that I added an extra big oring under the lens to make sure it stays tight. (available at true value hardware)
The 5/8 hose going half way down the light fits right over the pvc valve I used. you can put this together in 20min
price for light--$20
price for other parts--%9
I wanted to be able to see through the the lens but if you dont want to bother with drilling a hole through the lens there are a few pvc grommets at auto zone that fit tight right in the body of the light if you just want to leave the light bulb housing off (just unscrew it and discard)
way to go dusty... i got the kazuma and was wondering about increased volume of blow by as well.. awesome job on a budget; and i got an extra mag that size as well. keep us posted on how it works for you. looks like youd have lots of options on where to place that unit as well.
