MAF efi problems
Boulder, CO
I have had my rig to two different mechanics trying to get the MAF efi kit running properly on a new MAF hi performance re-built engine. Neither one has been able to figure it out despite numerous phone calls to MAF and Turbo City. They have recommended many fixes but nothing seems to work. Has anyone else encountered this many problems with thier efi kit? I am about to go back to a carb'd engine or ship it out to Cali to let them figure it out - I'm pulling my hair out and I don't have much to spare.
Send a call out for Steve-O he is the MAF man in the know... he hangs around this forum~ you start bitchn' here and he'll pop up!
Idles well - take it out and it starts to stall when you let off on the gas. Made many adjustments per suggestions from Turbo City but it still runs lean and a little hot. Confuses Turbo City because they say they tend to run rich because of the intake manifold design of the 2F. Outer pistons do not get as much fuel due to the length of the intake manifold so they intentionally make them run rich. Have even sent it back for re-mapping (i think that's the term - I'm not the mechanic here) and still not running well and basically weak. General lack of power and as the engine heats up it starts to knock and stall.
I was there when the mechanic checked the fuel delivery and it was OK. I don't know what you mean about the vacuum leaks.
Any air that gets in after the throttle body can cause problems. The efi maps assumes there are no leaks between the throttle body and the cylinders.
The 2F intake is notorious for leaks at the head. The MAF adapter can leak where it mates to the manifold. Any of the vacuum hoses can leak.
how do your plugs look?
I would look for other sources causing your problem. You might be working on treating the symptom and not dealing with your problem. You should look at things like vacuum (like mentioned earlier), timing, ignition system, Valve adjustment fuel delivery and return, etc. They are probably overlooking the problem, most likely pretty basic.
This is where I would start personally. The most common problem we have found would be a vacuum leak. Have your mechanic check for a leak with a vacuum gauge. It should be reading around 17 inches of vacuum. We do provide a new ignition system with our TBI kit, but do double check the timing and spark plugs.
I have printed out the discussion here and faxed it to my mechanic. Thanks for the suggestions - hopefully it will be the key to driving my rig soon.
