I haven't gotten them yet. I was trying to get a jump on things. Thx![]()
I did not have to raise the truck either.
You disconnected the part that holds the axle in place without supporting the frame? You're a lot braver than I am.
-Spike
It seems foolish to remove suspension parts without supporting the truck. Foolish and pointless, I can't see the advantage.
At least you were smart enough to put the jack stands under there- but why not use them, rather than chance the truck not falling just right onto them? Am I missing something?
-Spike
What's going to fall on you? Short answer, the truck. If you remove the bolts from the radius arms, what's locating the axle under the truck? The driveshaft? You went to the trouble of chocking the wheels, most people who relate their method of removing the front arms don't even bother do to that, or only chock the rear wheels. The panhard keeps the axle from moving sideways, but without the radius arms what's keeping it from moving either forward or back? You're supporting the weight of the truck on two coil springs, with nothing but the shocks and driveshaft to keep the axle from either twisting on it's axis or rolling forward or back.
So I'll throw it back at you: what holds the axle in place? What's keeping it under the truck, and why is it smart not to support the truck's weight? Is there some advantage that I'm not seeing? Some disadvantage other than having to pull out a jack and stands?
-Spike
Crawl under and have a look at the front and rear sides of the axle and its relationship to the frame of the vehicle.
If you feel safer doing it in the air and think it's necessary, by all means...do it! There's always more than one way to go about a job.
Here's a cut and paste from the directions posted on a familiar 80 series vendor's webiste.
http://www.sleeoffroad.com/technical/tz_ome.htm
The first step is to secure the vehicle. The vehicle should be on the ground, at normal ride height. Secure the vehicle by blocking the rear wheels.
MAF sucks with instructions, nothing I have every bought from them had them, thats my only negative remark. I put my truck on large jackstands to do the install
