Machinist in SLC?
I might be able to recommend a place. What exactly do you need done?
tanked, passages blown out, block decked, head shaved, cyl bore (+.020 I hope), crank grind/polish if needed. one of the main journals has a small bugger in it. (polish?) line bore check and done if needed. crank is ink penned .010/.010. i havent broken the mic out to check on that yet. install the cam bearings. I cant find my installer (i think i loaned it out, cant remember who to)
i have to pull the valves and see what shape the guides are in. knurl or install new (cost vs) valve grind if needed. the PO said that the motor had just been rebuilt which i tend to agree with because of the condition of the bearings (still had the light grey babbit face) and all the gaskets werent soaked and burned in yet. do the freeze plug kits come with the ones for the head??
the thrust face on the #3 journal was the worst face on any of the bearings.
Any body ever use a heavier valve spring (I.E. Chevy)
