M101 parts
Status
Not open for further replies.
Seattle
looking to sell the original M101 wheels (2 of them) in great shape (black) with very good military tires on them. ready to go. $60 each
Both M101 hubs $40 for both
M101 original brake lights $30 for both (these are the real ones not the plastic ones) and come with the M101 brackets, just bolt them.
M101 reflective triangle (the ones that came on the back of the trailers)
Have both but ones broken so Ill lell the other for ($6)
M101 Wiring harness. this is the original wiring that goes to the the lights (sorry plug not included) ($15)
all these prices do not includ shipping. I can take pics of all the stuff if needed
Mike
pics
Are those tires 700-16's? If so are they weathered checked at all? Mine have tread but are beginning to crack all the way around.
sorry the lights sold with in 15 min that was fast, as for the tires they appear to be in excelent shape. Not sure what you mean as far as weather checked but i can have them checked for you if your intrested, is this something i can do at a local tire shop? from close inspection out side they appere to look like brand new no cracking or weathering.
thanks
mike
Yep, was just asking about any small cracks in the sidewalls. Sounds like they are in good shape. If you can take a close up of a sidewall with the tire size that would convince me. Thanks.
after close inspection you can kinda see cracks, i think there cracks it might just be rom over spray with the spray pain when i painted the wheels. ill look again when i get home and see if i can take some better pics as well
Thanks for the pics, now I'm not sure if they will fit on my M416 trailer or not. My tires are TUBED and 700-16 in size. It is also a 5 lug bolt pattern but I'm not sure if your wheels will mount up on my hubs. I like the idea of switching to tubeless tires like you have there but my knowledge on these trailers is limited. I know what you have so instead of wasting your time and having you measure and what not I will try to research on my end and see if I can run your wheel/tire combo.
Thanks again and I will get back to you with what I find, if someone wants them before I can answer well then it's my loss.
I read that the Canadian M101 has a 5 lug bolt pattern that is metric and the USA M416 has an "english" 5 lug bolt pattern which is slightly different.
Assuming you do have a Canadian M101 which is almost identical to my M416 then the wheels will not swap over.
My trailer is canadian m101 did it say anything about the hubs being able to work on your trailer?
mike
mike
I didn't research that far. I have good hubs and wheels, just my tires are weathered. That's what I was really after, I would have to run the wheels too since mine are for tubed tires, I imagine mine wouldn't seal a tubeless properly.
Thanks though, too bad the lights went so quick, needed them too.
Status
