Lx700h dual battery system
AZ
Anyone install a dual battery system in the 700h?
If so, any advice where you mounted the 2nd battery, what isolator you used and AGM vs LiFePO4 setup?
Thanks
Has anyone done this? or put agm or li battery in the rear compartment? im thinking of going to agm with stock battery at least as i do not want battery acid getting out later on in the rear panel.
I have a 135 Ah Dakota Lithium instead of the factory option. For now using a bluetti charged thru the NiMh to keep the fridge going
