need some feedback from folks here.
I have decided to get the Front Runner Slimline Roof rack. Front Runner customer service confirmed LC300 model should work with LX700 as roof assembly is similar, but they have not fitted it to LX700. Rack costs around $1900.
Gear up your Toyota Land Cruiser 300 for any adventure with this Slimline II Roof Rack Kit. The Slimline II’s lightweight, modular construction allows you to customize your setup with over 55 accessories. This particular cargo roof rack kit contains the Slimline II Tray, Wind Deflector and 2...
www.dometic.com
I did my research to check LX700h and LC300 roof assembly, they both seem to have same roof setup.
LX700h
LC300
LX700 does require lowering of headliner but with following parts it looks like supported roof platforms can be connected using the bolts from the top.
I have worked with local Lexus approved body shop which give me an estimate of $1000 to lower the roof liner and install the bracket and retainers. With this option I will need to install the Slimline roof platform myself or later connect with roof rack installer.
local 4X4 shop give me an estimate of $1800 to install the brackets/retainer, and also the roof rack.
Wanted to get feedback on this effort
a. should I go ahead even with this effort. Seems like no one has actually installed the roof bracket/retainer or this roof rack on LX700h.
b. Are installation cost reasonable.
c. any other watch outs.
Based on my research and similar setup for LX600, I have high level of confidence this should work as expected.
