Any tips on getting the seat back off without breaking stuff?Problem solved!
After consulting with another LX owner on an LX570 Facebook group, he figured it out. We both had exact same troubleshooting steps: checking all the fuses, under-seat connectors, switching out ECU and the only thing that was missing was a plug that was located behind the seat-back area. See pics below:
This is what it looks like after you remove the back cover of the seat. It's a relatively straight forward process. Loosen two bungee straps on the bottom, remove two screws in the mid-section, then pull the backing downward to remove.
After taking off the back cover, there's one white plug that's right next to the vent. Upon a closer look, the wires attached to the bottom portion of that plug had somehow broken clean off.
To fix this issue, I had to break off the last hanging wire, re-pin the entire plug with new wiring and then solder the new wires onto the existing wiring harness.
To remember which colored cable goes where, I marked the original locations with G (grey), Gr (green), B (blue), and R (red).
I added some solder to the pins to ensure the connections are secure.
Now solder them to the existing wiring harness.
Once that was done, I plugged it back in, and Voilà! The heat/vent both work now. I hope this helps those who are still struggling with their broken seat climate issues.
I am good at breaking connectors and plastic trim pieces.
