Hi all,
I am still fighting to repair my AHC system on my 2000 LX470 and after a trip to my local Lexus dealer am convinced I need to fix it myself.
An explanation of the fault:
The AHC 'OFF' light is constantly blinking on the dash indicating a fault.
The vehicle has lowered itself to the lowest positon possible and is now undriveable as i don't think there is any fluid in the shocks.
Trouble codes:
I have taken the LX470 to Toyota and an independant mechanic to have their scanner connected. The Toyota scanner showed the following trouble codes:C1718 & c1762. The mechanics codes were C1751 - Continuous current to compressor and C1762 - Abnormal Oil pressure to pump.
Thinngs I have tested:
All height control sensor have been checked and are working correctly.
All AHC relays were tested and working correctly.
The Height Control Accumulator solenoid was tested by applying 5volts from an independant supply. I could here it click closed so assume it is OK.
The four solenoids in the Control valve assembley were checked by applying 5 volts. Althought this test was only guess work. I checked resistance between the pins and found a common pin which I assumed was the negative side of each solenoid. Again I could here the solenoids click. I would still like to see the correct pinout of the valve assembly to check it more accurately.
Connection between above sensors and Height Control Accumulator to the AHC ECU has been checked and is OK, as is connection of the pump pressure sensor and temp sensor to the ECU.
I have checked resistance between pins on the Damping Force Control Actuators (which the round gas filled spheres or chambers are attached to). The actuator consists of a 16 step DC stepper motor. The resistance between each pin was the same on all four actuators so I assume they are working OK. Tho I am not sure if these are 'normally open' or need power to allow fluid in and out of the shocks??
I have removed the AHC Pump and run it directly from the battery with a pressure gauge connected. The pressure rose to over 1500psi before stalling which I beleive would be enough to power the system. The pump motor only drew about 8 amps at this point which I also beleive to be OK.
Things I need to test and get more info on:
The pump pressure sensor. Does anyone know how it operates? It is a 3 wire sensor and in my vehicle is being feed 5 volts from the ECU and one side is connected to ground. I assume the other pin is the signal output which I further assume is a variable voltage output - different voltages for different pressures. Can anyone confirm the operation of this sensor? What should the voltage input be? Is it a variable voltage output or is it a milliamp output?
The pump working pressure: Does anyone know what pressure the hydraulic system should operate at? I have documents showing the sealed gas pressure of the Height control Accumulator is 853psi and would assume the 1500 psi I ran it to would be sufficient.
The Control Valve Assembly:
Does any one have the pin out for this assembly? I would like to find out which pin drives each of the leveling valves and gate valves.
The temperature sensor: The temp sensor is connected to the pump housing only and is not in direct contact with the hydraulic fluid. Does any have any info on this sensor?
The ECU: Does anyone know how to reset the ECU so I can reset it between tests?
That is about it for now. I have spent many many hours on this system and probably many more. My wife thinks I am obsessed but I think it's just a hobby - tho a frustrating one at times.
Sorry for the long rambling email. Any help would be appreciated.
Cheers
Fish933
Trouble codes:
Cheers
Fish933
