LX470 Rear ABS Sensor removal
phoenix
I am trying to replace the rear ABS sensor. For the life of me I can't figure out an easy way to disconnect the sensor cable from where it is attached on the frame of the vehicle. Easy to remove from wheel, but above is difficult. Does anyone have a trick or pictures showing how the accessed it.
Which part in here? The ABS sensor is secured by a 10mm bolt. Are you referring to the plastic clips?
I am referring to the actual harness connection. Follow the ten or so plastic clips up the frame. The harness connects to another harness right above the axel on the frame near top shock connection. That is what i need help understanding how to access
Did you ever manage to solve this issue? I am experiencing a similar issue. The abs sensor itself is fine, I have managed to reach the connector (on top of the shock mount), but it appears that it splits into the loom a little further. I suspect I have damage on that piece of the loom. Resistance on the abs sensor gives me 1.0 ohm, but I do have an OBD error code for a short circuit on the sensor. Seems impossible to get to unless you either lift the body of the truck, or cut away a piece of the wheel well/splash guard. Let me know how things went for you.
