LX450 Wont start - help please
Calgary
Stopped off to get some vidoes at blockbuster and it would not start afterward.
Details:
-no cel in on position
-efi fuses (in cab and under hood) checked and appear fine
-Scangauge would not connect
-97 lx, with 112000 miles
-It got me to work, and to the dealership for a few new parts, and part way home.
-modifcations since the hg/sc install include a scion radio and a scangauge
-put on about 2500 mi since the hg/sc install, lots of highway and city driving
-it was cold today and got warmer later in the day, but i really doubt that anything is heat cycling
These clues lead me to believe that the ecu has no power, but I dont understand why.
It has done this twice before, just after my HG and SC install, but not since. I never did figure out what was wrong because it started fine for several months. The first few times it happened I checked everything I could think of. All the fuses and relays, the fusible links, the wires near the egr were fine, and I rewrapped them in fibreglass tape. The only thing I did not check was power right to the ecu. It started working just before I got that far.
I will research my EWDs to see wehat else it could be. Any help would be very much appreciated.
Karl
What happens when you turn the key? Do you hear the solenoid at the starter clicking when you turn the key?
Yup, it turns over, and all the lights in the dash light up except the MIL (CEL). I can crank it till the cows come home, but no starting.
Did you see what voltage you have at the battery? From the battery to the starter? Have you checked the battery terminals to be tight? The power wire at the starter for corrosion? Then gound for being tight and/or corroded? The starter terminals may be wearing out. They are like $20 or less and take about 30 mins to do. Another thing you may that you may want to look at is the ignition cylinder it-self. Try giggling the key inside the ignition while turning the key.
From what knorrena just posted, I can only assume that the starter is cranking, but the engine won't fire...
My first guess would be that, since you've already checked the fuses and relays to be good, the ECM is on it's way out... BUT, it could be something else:
-double-check all fuses and relays
-break in the power wire
-short
-bad ground
Just my $.000000002
I am pretty sure we have never seen a complete failure of the ECM.
Double check the EFI fuse under the bonnet. Check it with a meter. PM TrickyT, he is amazing with the EWD.
If the MIL is not illuminated then that is your first clue and as the others have posted, that means you are not getting power to the ECM and she ain't gonna start till that thing gets power.
-B-
Thanks for your support. I just got home from having it towed home - all of .7mi. It still turns over fine, no shortage of power from the battery at all, just no ignition. Last time I checked right down to the coil and its associated parts , even the crank sensor.
I am kinda tired and am planning on getting a good sleep and tackling this tomorrow. My plan is to start from the the battery, fusible link, fuse under the bonnet, efi relay, and all the way down the line. Fortunately I bought all new parts when this happened the first time. I left the battery unhooked for overnight. I will be super pissed if the ecu being reset gets it going again: i just spent 130 bucks to have it towed, and if it works after a reset, I still dont know what caused it.
Karl
Fixed, I think. I checked all fuses and fusible links, and relays, and found nothing. then I went around and checked wiring harnesses by shaking them and found that as soon as I shook the harness near the alt, the MIL lit up. I pulled the battery tray and ripped open the harness and found the splice for the efi power was corroded. Not as much as I would have thought it should be for complete loss of power to the ECU. It must be voltage sensing, and the little bit of resistance offered by the corrosion dropped the voltage enough to cause a problem. I am not too happy with how I fixed it: I used yellow eyelet crimp fittings that I bolted together and wrapped it with super88. My crimp tool was not big enough to handle the single 8ga and 2 10ga wires. The final splice was small considering how I repaired it. Anyway I am glad I found it - or at least I think I did.
Karl
Unfortunately no. My wife took the camera with her to my sons skating lessons. It was a toss-up, pictures of the kid or the cruiser.
Karl
