LX450 u-joint questions
Spokane WA, USA
I pulled both my '96 LX450 driveshafts loose at one end to see how the u-joints feel and I have one slightly tight joint (free in the center but binds as you move it sideways) and one slightly loose one. None are what you would call "bad" but I like to do preventive maintenance and think I will replace them all so I will know for sure that they are in good shape. The maintenance history is pretty vague on this truck.
Can some one clarify what the service manual is talking about in the Propeller Shaft section (page PR-7)? I measured the rear prop shaft length and it was 24 inches between welds (Type A) - that makes sense in a way.
What's with the colored bearing cups and drill marks on the yokes? Mine has neither as best as I can see. Do they require different part number joints?
What is the consensus on doing this job myself with a big vise vs having a driveline shop do it? Is balancing recommended? I've never replaced a u-joint, but I have lots of tools and a couple of BFHs and would kind of like to learn how to do the job by myself. (I have a center diff switch so I could do one shaft at a time.)
Do new snap rings come with the new OEM u-joints?
Thanks for any additional advice.
John Davies
96 LX450
I replaced all the u-joints on my 80 and it was not fun.
The caps on my joints were so tight that I had to cut several of the to get them apart.
I fired one or two new joints getting them back in.
I replaced them as a PM, they didn't need replacing.
As "I" usually have these kind of problems when working on the 80, your experance may/shouldn't/won't go as bad as mine did.
John,
I've also read through that section on a rainy day and contemplated doing it as PM. I called some driveline shops and got a bit more info.
First off, it's actually somewhat like setting up bearing preload by using different thickness spacers as shims - for each of the 4 bearing journals on each joint. So, some experience is good because it's a "feel" thing. Sure, you can just slap new ones on there, but you'll end up with much like what you have - a couple loose ones and a couple tight ones. The driveline shops do U joints several times a day and they were very reasonable on doing these. One shop said it would be an hour of shop time if I brought both shafts and new parts in, or they could get the parts (I prefer using OEM parts).
So, it's not rocket science but there's some experience based skill involved in picking and choosing the right tightness. I seem to recall the FSM explaining some way of using a feeler guage to see if the proper spacers were used, to decide if its best to go thicker/thinner.
Also, if you get in a tight spot on your birfs, call me as I'm just an hour away and have a full repack kit around and some remnants from another repack.
DougM
From my experience, a slightly tight feeling is good. When the U-joints move around like mash potatoes, you've got a problem. Probably hear squeeling swallows too.
My problem is not a slightly tight joint - it's that it is free in the center then gets progressively tighter as you move it to the limits of its travel. That isn't a good sign. The feel should be consistent in all directions.
John
I dunno John. If by center, you mean when the shaft is straight then I'd say this is normal as that's where the journals run. The shaft never runs at much of an angle, so uneven tightness at those angles may not be an issue. Obviously you have to make that call, but that's how my rear shaft felt at 135,000 miles with lots of heavy duty towing.
DougM
John,
DougM
old thread. but what do you do on ordering the snap rings? do you measure what you took out and then order the same? or check the color and order them before you uninstall it all?
What he said ^^^. Notwithstanding what you may have been led to believe, it is about as complicated as a rock.
Mark...
I have never seen any ujoint that uses clips not come with new ones. They are not always the same from brand to brand, or even for the same brand over time. Not to mention that stretching them on and off can bend them.
Mark...
