LX450 starting issue
USA
About once a month I have an issue when I start my 96 LX450. The truck always starts but occasionally it runs crappy. The first time this happened I turned the truck off and restarted and everything was normal. The last two times this has happened I turn the key to the OFF position and the starter starts turning over. I turn the key back to ON and the truck is still running crappy. It will do this several times before the engine turns off. Once this happens I can restart and everything is normal. Your help is appreciated! Thanks.
Would you know the sound of your starter sticking?
I'm dropping that as my first guess, based on your wording.
I don't hear any unusual sounds when this happens. What would the starter sticking sound like?
I'm with Linus, particularly because of your wording. The sound is usually pretty vicious, metal on metal grinding sound. Once the engine starts, the engine is spinning much faster than the starter so it's pretty bad.
Prob not the starter then, you'd swear it sounds something like tossing your keys in a blender. Like mentioned, it's pretty vicious of a noise.
Do you mean your motor is "dieseling" - running on after you shut it down?
Your 1st post made it sound like there were sounds to this, so kinda need better description otherwise this is blind guessing, you know?
Definitely no 'keys in the blender' sounds when this is happening. And motor is not running when I turn the key off.
Truck wouldn't start this morning. Turned key on and got the 'click' that I've read about in other posts. Battery is at 12.6V. Left key in ACC position for a while and verified radio is working. After having key in ACC position for about 30 seconds tried to start again. Starter sounded very weak but truck started. Battery at 14.5V when motor running.
A sticking starter doesn't always have any grinding or loud metalic sound. With the click and no start that points to worn starter contacts for sure when the battery is OK. Replace the starter contacts and plunger and that should fix both symptoms.
Blind Squirrel - 1
Your 80 - 0
Glad it worked for you, chasing crap gets tedious.
