LX450 Cooling Question
Wyoming
I've got a buddy with a '97 lx450 with approx. 115,000 miles. A few weeks ago, during an extended road trip, he noticed the temp guage was starting to climb. He had one of the L/C specialty shops check it out and they said it looked like his head gasket was showing signs of failing. He had them replace the head gasket, thermostat, fan clutch, hoses and even the radiator! The truck ran good for about two weeks and as of this past weekend, the problem is starting to show it's head again. When he climbs the mountain passes on I-70, the temp gauge climbs to just about 3/4 on the gauge. It normally runs just below half. He's going to call the shop tomorrow but we figured we'd ask on here to see if anyone else has experienced this. Thanks in advance!
Bob
Bob, the stock temp gauge does not have a linear correlation with temperature.
There is a temp mod (by RavenTai) or other methods (i.e. ScanGaugeII) to get an accurate reflection of engin temps.
As for climbing hills, my temp gauge did the same prior and after HG job, thermostat, hose, etc...on long, steep inclines.
Others will chime in.
But the only way to get accurate help is to get accurate data and the stock temp gauge is not a good method for it.
Check the tightness of the belts.
Check the fan clutch.
Check the coolant.
Check the radiator (open the cap) to see if it's visibly plugged.
Maybe the PO modified the gauge so that it reads accurately, using the mod mentioned here.
Since it's a '97 and since he's obviously dumped a ton of money into the rig, invest another $170 in a scangauge and he can know EXACTLY what the temperature really is after doing nothing more than plugging the sucker into the OBD II connector.
ScanGaugeII - Trip Computers + Digital Gauges + Scan Tool
I would expect temps to climb after long hill grades at freeway speeds. My temperature, after a complete coolent overhaul, similiar to what your friend had done (not including the headgasket) is about 181 with normal driving and normal ambient temps. This can go as high as close to 200 on extremely hot days and long hill climbs..maybe even higher at higher elevation and really, really long hard pulls, especially on hotter days. So it would not be abnormal to have a wide variation of temperature depending on operating conditions.
The only other thing is did they "actually" replace the radiator? The radiators of these rigs have a nasty habbit of collecting grey sludge which plugs the tubes. Many of us, including me, have found that this disables some or much of the radiator's capacity and it may not be that noticable during normaly driving, but rears it's ugly head in severe driving conditions.
Thanks to all. These are all great ideas and will give him some places to investigate. I've seen the scan-guage mentioned before on a bunch of rigs. Maybe time to investigate further? I'll post his findings when we have some. Thanks again!
Bob
last year i moved from the denver area to phoenix. in colo, i really did not have any cooling provlems. the un modified gauge on the truck would climb slightly when going up the mountains, but not severe enough to mess with. only once did i have a moment that the gauge got to the red zone. anyway....
once i moved to phoenix, the temps got my attention, so had to address. recently modified my new style blue hub with 20k cst oil (thanks kevin), and also replaced the foam on top of radiator. i am now able to drive around town with the ac on and no over heating.
i would say to make sure the foam is on top of the radiator, and put at least 10k cst oil in the fan. i would go ahead and fill it with 2 tubes. the write up is here somewhere. as the fan is a lil more drag on the engine, and the ambient temps there are not so bad, this would prolly be sufficient.
just my .02.
