lx450 climate control
More info on the rig
All maint up to date.
plugs
wires
air filter
fuel filter
axel service
dist cap & rotor
complete exhaust
completely stock less 285/75r16 procomp allterrains
pics later this evening
any ideas on the a/c issue
Hi. I recently got a 96 LX450 136k and have the same issue. I have been driving a 96 fzj80 that never had any such issues. One thing to check that I know is bad on mine is the fresh air inlet servo located behind the glovebox. Even when the fan is turned off you can see the arm from the servo that opens/closes the flapper for fresh/recirc continuously cycle. Turn the switch to recirc and the servo stops cycling. Don't know if this problem is related, but you can easily check it by looking under the glove box and looking for a moving steel arm and listening for that annoying noise. I found the thread for the broken servo here: https://forum.ih8mud.com/80-series-tech/66085-vent-cycles-between-fresh-recirc.html
Hope this helps! Congrats--sounds like you found a great truck!
