LX subwoofer test?
Seattle
There's not much of a bass presence in my LX. I suspect my sub is not functioning. Is there anyway to isolate it or test it otherwise? I'm no sterophile so bear with me...
Sub?
In the LX you have 4 fronts, 2 rear and 1 mid if memory serves me right. I don't recall removing a sub. The LX never really had good bass I thought.
i think he might referring to our paltry center console sub, if one could call it that. while it does put a very little amount out, it does put some.
I am hoping that the LDD subwoofer gets done soon, its been several weeks with no word.
jon.
jon.
Yes, the center console sub. I can feel vibration from it but cannot determine if the vibration if from the other speakers or the sub itself. Is it easy to access (so I can view it working or not)?
LDD subwoofer? What's that?
Yeah but its a mid. And they go out. Mine works fine but it took up valuable real estate :D
If yours is bad I could be talked into selling mine :D
Remove the console (2 buts in the deep well, 4 10mm head screolts (screw/bolts) and 2 phillips screws and it comes off. Be sure to pop the plastic around the cd changer so it doesn't hold it up.
You can then visually verify it is working.
Mine had been unplugged (under the speaker (another 4 phillips)) so check that.
Brett
yeah its easy to get to. There are (4) 12MM black side bolts holding the center console in. Then there are (2) 12MM nuts inside the larger compartment. Now its a good idea to loosen up the front console so that you can maneuver the center console out. Once you have it out then you will see the big black box with the speaker in front. There is a single white plug going into it.
I have an easier way, put a small thin paper in the vent in the center console, if you hear and see some distortion it is working, you will see the small paper vibrate!:o
I would open it anyway. Stuff gets spilled on that thing all the time. I was worried what I was going to find when I opened it up. There is a very fine mesh screen which helps but you can see where some liquid made its way through. On mine it was easy clean up with no damage but who knows how yours is.
Thanks everyone for the info. I'll dig into it tonight and see what's going on.
Thanks - I'll keep that in mind:D
That speaker is very suseptable to large sonic drink spillage.....
Ow! That Pun hurt my 2 ears! I took my new 77 FJ55 to Pueblo in 78 for my act as Best Man in the owner/mgr of 3 Sonics marriage! Those LARGE styrofoam squeeze-me-please cups were pre cup-holder era! :grinpimp:
The 4 inch SUB in our LX became apparent after the install of the 5.25 pocket rockets. IF I didn't know better, & the human ear were more directional sensitive to low frequencies, I'd say the SUB was to blame. I have some B & O panel speakers to rebuild where bass is provided bY ONE FIVE INCH woofer + ONE FIVE INCH passive radiator.
Has anyone installed Aura Pro Bass Shakers in an FJZ80? I wonder IF the feeling of bass couldn't be had for significantly less than an actual active subwoofer in the back might produce?
Not to hurt anyone's feelings. (PUN INTENDED).
i found that the center console sub in my lx was not working and just seemed to be a waste of space. i took it out and put my external cb speaker in its place to keep it out of sight and buttoned everything back up. i installed a blaupunkt powered sub enclosure in the back. good luck with your sub troubles
Good luck... if it works, It prolly works best as a speaker for the CB ;)
Works in mine as one
Bx
I removed the console last night. The "sub" is working (can see and feel the diaphram move). I disconnected it to see the difference when it's removed from the system. There's not much difference. Odd. Maybe it's otherwise compromised and I just don' know it.
If you want to test any speaker, "tap" a AA bettery across the speaker leads, you will hear the speaker pop or click, if that dosen't work try a 9V, some high resistance speakers won't be pushed by an AA. If you are having problems this will tell you if the speaker or the amp is to blame. And no it won't hurt anything, I install High end home theaters ($100K +) for a living......
