LX is eating front tires. Another stupid Alignment Thread
Hello folks, all thank you for the advice. Took some time to see how things feel over a little bit of time. I adjusted air pressure to 40-41psi. While the pull isnt noticeable I found that the drivers side front tire inside is getting chewed and overall it does feel like the suspension isn’t right when taking a bump. Which may be caused by the mismatch side to side like you mentioned. Unfortunately I am up in Albany Ny for the next month and cant get back to the shop in VA till after. Trying to limit miles and save some tread. If anyone knows a shop up that way they can recommend it is appreciated.
What shop do you use in VA?
Folks thank you all for the information. A couple of things. I was under inflated due to running LTs but also my setup was off. So far this new set up is feeling good a few good roadtrips will let me check wear too.
Yeah those specs look pretty solid. I typically try to go for a tiny bit of toe-in and a tiny bit more caster, but overall I'd expect you should be pretty happy with these. If you're still getting odd wear after this, something else is off
Yeah i’ll keep an eye on it now what surprised me was my rear end, need to take a look at whats going on there now. Always something.
