macneill said:Hmmmm... that Doctor By Pass thing looks interesting.
Or am I just going to run into Dr Problems?
CTapia said:MacNeill,
I did not use the Dr. bypass module. The hack is simple, cut the vehicle speed sensor (VSS) wire and the e-brake wire. You then ground one side of the e-brake wire and you're done. The thing that I don't know is if the e-brake wire and speed sensor are on the same location (harness) as my 04. Perhaps someone with the factory manual can look this up for you.
r3run33 said:hello ctapia i tried to look back in the forum for how you did your lift of the ahc do you know where it is or if you have time can you go over what you did again to fit those tires in. thanks
ZUREK said:Check out this link. It shows how to bypass navigation in LC... might be helpful. http://www.pbase.com/drexx/dvdnavsystem
Also I don’t know if it is true, but multiple people told that if police catch you with tv on that is visible to the driver (IL), they can charge you with consequences similar to DUI! Is it truth or just bull???
e9999 said:not a good idea IMO
mikeacs said:Don't cut the VSS wire, besides the speedo and ECM needing this signal, If you cut the speed sensor wire, your Nav unit will not track properly as it uses this unput, along with the gps signal to plot your position on the map, and calculates your eta. I have seen devices that interrupt this signal every 20 seconds or so to allow DVDs to play in motion, but it seems kind of not worth it to me.
I am waiting for the Viastech video IPOD module to be ready, which connects to the cd changer input and will allow you to have 15 hours of video or 15,000 songs available, and all selectable through the Nav display.
That will be cool......
Gene3x said:CTapia ... yours is an 04 LX and mine an 04 LC they should be the same right? Do you remember the color & location of the wires?
mikeacs said:Ctapia, I knew about going into the rear video system, but they are supposedly (viastech) about to release the harness that ties right into the nav and actually displays the song or movie titles. anyway that sounds like a pretty cool setup with the rear video you have there
