LX 570 sensor lift
Texas
Trying to do a sensor lift on my 2015 LX 570. I read the instructions on one of the threads on here. Pretty simple process. There are adjustment slots at each corner of the suspension. To raise the front you slide the slot down and in the rear slide up.
the problem I am having is I am having trouble getting the right and left front to be the same height. I am measuring from the lip of the wheel well to the top of the rim on each side. Does each corner adjust independently? They are about an inch off from each other
Small adjustments can make a difference. You need to at a minimum cycle the suspension, but more likely drive for 5 min or so to see what the new setting will get you. You can move them with the car on and it will adjust real time as well, but tends to change a little after some use.
The sides are independent in front. If trying to match move one only.
