Lx 450
It may be sticky. Give it a good yank, that's what mine took the first time I did it. Do it in Neutral, too.
My buddy just bought a 97 LX450 for a project truck.
Any way, could not figure out how to shift the transfer case into 4 LO
tried putting it in neutral, tried rolling in neutral.
When you pull on the stick it feels like it is locked?
any insight would be great
If it does not shift cold, try driving the vehicle to get everything
warmed up and try again. Did he try it with the engine off??
Also, have your buddy read the instuctions on how to shift into low to make sure he is doing it correctly. I would check the gear oil (quality and level) while you are at it, some duffus may have put the wrong oil in there; but it should still shift manually either way.
G
Well my first thought was that it is seized. Kinda ran out of time last night. I'll drench the linkage in penetrating oil and giver another haul. Oh and yest I tred with the engine off, also truck rolling, stopped, neutral, gear. It's stuck good!
Oh ya he has no manual. I just figured it would be the same as my Surf. gear selector in neutral, shift to 4 low. easy peasy
Try putting it in Neutral and ensure the e-brake is pulled! I have a 5 speed cruiser and in order for me to shift into 4L I have to put in "neutral" and pul the e-brake before putting it into 4L!
I test drove one like this.
Make sure it is in Neutral, engine on is OK.
Put the E-brake on.
Sit on the console with both feet on the dash and PULL the Hi-Lo lever. Just be careful not to knock the gear shift lever into drive.
