Lug Torque Setting?
San Diego
I am going to be mounting some FJ Cruiser wheels on my LX450. I've read that the torque setiing for the FJC is 85lbs and the 80 series is 105lbs. Which setting do I use?
Edit: FJC alloys with the oem conical lugs
Edit: These will be mounted with 1 1/2" spacers as well so what torque setting for the spacers? Okay, i just found a site that recommends 75-80lbs for the spacers.
The torque setting depends on which wheels and lug nuts you use, not which truck. Steelies or alloys? Acorn or shank?
Edited the original post- FJC alloys with oem conical lugs
In any case, per Romer in the Front axle rebuild thread in the faq-
Steel wheel and alloy wheel with conical seat lug nuts, 109 lb-ft.
Late alloy wheel with shank nuts, 76 lb-ft.
You sure they're not straight shank style?
I am glad you posted this question. It looks as though I have been misinformed by someone on the FJC section of this board. I asked which lug for the alloys and was told acorn but upon further research it looks like they are the shank style so my stock lugs from my LX should work, right?
...my stock lugs from my LX should work, right?
I'm not familiar enough with them to just say 'Yes', but I don't think there are different sizes of the shank style lug nuts, so I'll say 'Probably'. :D
Also, when I installed my spacers I found that the studs that are pressed in to the spacers were not fully seated, so they would get tight and then loosen. I looked for instructions and found none, so I torqued them all to 105 foot-pounds, then loosened them and re-torqued them to 76. That seemed to seat the lug studs for me. I figured the studs were good for at least that much. You will have to decide what you want to do.
Thanks for the tip. I read somewhere to remove the wheels after 500 miles and retorque the spacer lugs and then repeat with the wheels. The paint needs to cure on the rims so I'll mount them this weekend.
My suggestion would be to add some red loc-tight at the second re-torque. These things have a nasty habit of working loose over time. It will make them a little harder to remove - but that's what you want anyway....
A wise man told me not to use Loc-tite on fasteners that you have a torque spec for, because when you go back to re-torque them you won't be reading the fastener torque. If the lugs were to loosen for some reason, say there was something on the mounting surface that compressed, you wouldn't know it and the part would be loose and possibly fail. Take that for whatever it's worth.
I trust the spacer lug nuts the same as I'd trust a wheel bolted on there. I realized when the lugs on the spacer pulled in that it was a possible failure point, and that might be where some people have had problems. I trust the spacer-to-hub connection more than the wheel-to-spacer connection, but I will be checking them both.
