lug nut seat angle
anyone run into needing a different seat angle when you switch to aftermarket wheels, I've got a set of wagon wheels off an early 70's chev, and the stock toy lugnuts don't seem to center them up very well and were causing the drums to bind, anyone know the size, pitch for toyota, and the seat angle for chev?
12mmx1.5
No clue on this...
However,
Many vehicle/wheel mfgs. have special lug nuts that would be required to properly mount secure the wheel...I am not aware of a special lug nut for a mid 70's Chev steel wheel....but that is not to say that one does not exist.
Good luck!
-Steve
thanks, I guess I'll take it to the tire shop and see what I can find, I just figured that there are a whole lot of 'cruisers out there running cheapy aftermarket steel wagon wheels (they aren't actually chev wheels, that's just what they came off.) , so maybe someone has run into this problem before.
Angle should be 60 degrees. But, the bolt parrtern is off by a couple of mm I think. I have a set of chevy rally rims that I bored the center out of on my 40. I need to keep a close eye on the rims or they seem to work themselves loose. I think it's from the slight size difference in the bolt circles that does it.
