Lug Nut difference?
I have a 92 3FE cruiser with OEM 15" wheels. I ordered 16" OEM 5 spoke alloys and will be mounting them with new Nitto TG's. Can I reuse the lug nuts or do I need to order new ones to fit the 16" wheels?
Hate to be stranded at the tire shop due to incorrect lug size. Those with experience, please chime in. TIA!
From what year were the 16's you'll be using taken? The "early" 16" wheels (I believe 93 and 94) had conical seats (and used tapered lugs), while the later wheels (I believe 95-97) have flat seats and, therefore, use shank-style lugs........I believe I have the years correct. Anyone?
Ah Crap! There's a difference in 16"?!? Going to check...I orded refurbished 16" off ebay...they look new, but not sure if they're all from the same year. So if they're conical, can I reuse the lugs?
I checked, 3 of the wheels are the same, conical seats. One of them has a flat seat. Can I at least reuse the lugs for the conical seats?
I would be guessing if I were to say yes or no. The lugs, obviously, fit your studs, but how do the lugs "fit" in the conical seats on the wheels? Do they look like they "match?"......I presume there's plenty of thread coming through the wheel? I'm assuming this will work OK, as I've seen plenty of 16's on older 80's, 62's, and 60's, but I'd just check it out to make sure everything is matching properly. Wheel fitment is an area where error is not acceptable.............
LOL, yeah, I definitely don't want my wheel to be coming off unexpectedly! Just want to make sure I have the correct lugs so that there's no delay when installing the wheels onto the truck.
If anyone has already switched from OEM 15" to OEM 16" please LMK if the OEM lugs are ok. One set of lugs are already going to be different from the rest of the wheels.
