Lucas X-tra HD Green Grease for front Axle?
Idaho
I use the Lucas X-tra HD grease quite a bit. I am going to rebuild the knuckles and replace all the bearings. My understanding is that I need to use Moly in the knuckles and wheel bearing grease in the spindles.
Would the Lucas grease perform both duties?
Lucas
What do you mean by lawsuits? Is Lucas part of one? Are you saying people are afraid to answer because I would sue them if their advice was bad? I'm not tracking.
Is there a preferred grease here on Ih8mud for these two applications?
I do not want to tell you to go ahead and use your preferred grease because your truck might break 4 years from now and I will get sued.
I might go out and buy some of the Lucas grease myself because it looks very good to me.
I bought some Amsoil 5% Moly for the knuckles and then will use Lucas for the wheel bearings.
Hey Dan, I see you've gone and bought a separate product, but I'll give you a rundown for future reference.
A "moly grease" contains molybdenum disulphide, which is an Extreme Pressure (EP) additive. Anywhere that you have very high contact pressures or sliding contact which may displace a grease, you'll typically want a grease with an EP additive. The same is true for oils. This is why gear oils for hypoid gearsets are typically marked "EP".
EP additives traditionally aren't great for high speed bearings, as they can cause skidding of rolling elements due to the moulding of the EP component from contact pressure. For this reason, a conventional lithium grease is recommended.
Modern lubricants have come a very long way however. Some are suitable for both high speed bearings as well as EP applications. Not all manufacturers specify their exact performance, so if in doubt, meet or exceed factory specifications.
Does anyone have experience with Li400? The maker claims it is safe for bearings but uses a ceramic component instead of Moly for the EP function.
Li400 -German Made
As a chemical engineer I'd say:
At high temps, MoS2 may decompose to (agressive) sulphur compounds, which may corrode a bearing. As @Jawsh correctly said, MoS2 greas is rather for comparably slow rotations, leading to moderate temperatures.
The said L400 I understand to be for high revs hot environments such as aircraft turbines. I have no experience with it, though.
Cheers Ralf
