LT1 oba?
My LT1 came with a good ac compressor on it....Denso is the brand i believe. Anyways, i know that these style compressors need freon to keep it lubed, but isn't this what the jeep guys use with their sanden compressors? If i was to routinely squirt compressor oil through the air intake portion, would it keep it lubed? I talked to local corvette shops and nobody even makes a bypass pulley for the corvette LT1, so if i leave it there i would like to make it work.
It will work for oba. They have a small "sump" in them for lube, an oz. or two at most. I would recommend using an air drier on the output side to catch the oil that gets ejected. Check the drier periodically and add back what comes out. I Don't think it would last long with continuous duty like air tools though.
