- Joined
- Jan 5, 2015
- Threads
- 9
- Messages
- 35
I'm currently in the process of endlessly bleeding my brakes after doing a full brake line and caliper rebuild. While doing this I noticed that the LSPV boot was torn and the axle-to-LSPV rod was not contacting the LSPV plunger. I assumed that the plunger rod was seized and I decided to remove the large brass nut in order try to unfreeze it (I realize now that this is not actually how the LSPV works).
When I removed it I noticed there was no internal coil spring inside the LSPV. Is that abnormal? I'm the 3rd or 4th owner of this '93 - so I think its entirely possible someone has screwed around with this valve previously.
