I have a 1990 hdj80, and the LSPV is rotting away from rust. The arm that connects to the axle is broken off and I´m sure the bleeding valve hasn´t been moved for many years. I´m sure it will brake off if I try to turn it.
My problem is I belive I have air trapped inside it, my brakes are spongy like there is air trapped somewhere. I have been bleeding at all wheels and no air is coming out and the fluid isn´t leaking out.
Last time I checked at the dealer charged a arm for a new LSPV, now I´m sure it is a arm and a leg, perhaps both arms.
It is almost impossible to find a used LSPV here because they all are rusted to hell.
So, I´m thinking, can I use a Wilwood Brake Proportioning Valve instead. I would add it to the brake line next to the master cylinder, remove the original LSPV and bridge the pipes from the front to the axle. Then close the pipe from the orignal LSPV to the front brakes at both ends.
Like this I will have full power on the front brakes, and can control the power to the rear myself.
What do you think?
C-Dan, If you read this, how much is a new LSPV from you?
What do you think?
