LSPV help for the idiot
Eicca
Professional Noob
Utah
I've searched and searched and searched and I can't find a basic guide that shows where the LSPV is, what it looks like, and how to adjust it. Can someone help me out?
Thanks!
THANK YOU! I tried searching the FAQ too but it never came up with results... Thanks again.
Searching for "LSPV" turned it up fine for me, second result. In all fairness that link is buried below it and would be easy to miss.
It's all good. ;)
Someone posted a while back that the FSM says to adjust the LSSA first and then the LSPV. However, most everyone (including myself) seems to only adjust the LSPV (Load Sensing Proportioning Valve).
I just can't find that post, but also search for LSSA (Load Sensing Spring Assembly). If someone could post a PDF of that page from the FSM, it would be great.
Took a look at it a few minutes ago... dang thing is rust-fused to the frame. I may disconnect the rod that runs from the LSPV to the axle and tether it up with some wire so it never knows how hard I'm braking (bwa ha ha)
