LS swap folks. . What wire did you tap into on the ignition switch pigtail?
take a picture of your engine bay. Do you know where your ecm is ? Do know if there is another fuse box added? If so where is it? AAAAAnd just seen your sig is this swap on a fj62?
It is a swap on a 62, yes. The wires I took the earlier pic of are not part of the PSI harness but I do have a fuse box that was added that’s adjacent to the relays and the E38 under the glove box.
Reson im asking is because there is some wiring that had to be delt with on the 62 side for it's nss.
Have you checked for blown fuse? Loose wiring. The swap was working fine before this problem?
I think I inadvertently disconnected the original starting wire at the connector between the ignition switch pigtail while pulling the downstream part of the connector to get some room to work. The “no start” started after I had been messing in there and got worse to the point it was nearly 100% if the time. The new wire gives me what I need. . .just wish i knew where it terminated. . .I can’t find the end w/o pulling everything out of the loom which i’m not doing.
