Lower transfer case gears - options?
Vermont
Wondering what my options are for putting lower gears in the transfer case of my May '85 FJ-60. Already saw the sets at $pector. I don't have that big of a wallet.
Thanks for any info :)
That is your option.
SOR sells Marks off road gear sets made in AU. They are the only option in this area for what you are looking for. Save your money...
Good luck!
-Steve
Can I put in a 203 reduction box?
Eli,
couple options but none involve lower gearing for the transfer.
203(or is it 205?) doubler? this will effectively give you another 2:1
H55($$1800) this is the yota 5spd tranny that ""should"" bolt up to your transfer if you have the longer setup.
Toybox- 1000.00 dollars+ driveshafts+crossmember mods and that gives you 2.3:1 gears for another 400 you can get 4.7:1 gears for that part....
SM420/465 to earlier 3spd or 4spd transfer case and ditch the FJ60stuff. Then later on you could save up more $$ for an Orion 4:1 transfer case from AA that is cast iron and mate that to your SM tranny.(problem with this set up is probably driveability but it is probably the best bang for the buck)
Switch your 3.70:1 diffs out for some fine spline 4.11s from and FJ62 OR even course spline 4.11s (probably OK for moderate wheeling.)
Ok and get some protectiong for the big ass you will have to deal with now!
Stew
