Lower rad drain plug??
Has anyone just went out and purchased a plastic kid's pool and shove the entire pool under the LC to catch all the radiator fluid during a flush :)
That's a great idea! I would drain it between flushes so it doesn't get too heavy to manuever and keep from spilling.
kiddy pool!
Dude .. that is a good idea too!
I know someone on here has the base of a rooftop cargo carrier that they use as a catch-all and has posted the pics before. I've been keeping my eye out for something similar.
The lower radiator hose is a good way to drain the radiator.
I always seem to make a mess draining the engine block, no matter what. I'm gonna think about this problem.
Who Spiked My Drink - Am I Color Blind?!!
Jeff - I'll reach out to you on email after this.
Okay gang, I've been searching the FAQ and reading everything I can find on both the topic of red vs. green and I now have two gallons of non-premixed Toyota red on the work bench ready for use. I don't see any commentary if I have enough in possession after a full flush to do the job? Dealer says the two jugs will make four gallons and that is all I need to refill the cooling system if I do a flush.
Question #1 - Anyone agree? (Waiting on FSM from Toyota Publications) Is two non-mixed = 4 gallons enough to do the job?
I am second owner of this '97 LX and the Ft. Worth dealer installed a new Toyota radiator for the PO at 86,000 miles, rig currently has 120,000 miles on it. The radiator says Toyota on it as well as having the docmentation from the national Lexus database that the local dealer printed out for me showing that they replaced the fan clutch at the same time. When I bought the vehicle, the local dealer and I popped the cap and it had fresh, bright green coolant that looked good to go. I then purchased Toyota red coolant with the intent to flush it and restore it back to OEM glory.
Now for the strange part. First, I'll admit I had two Tequila Sunrises in me last night and I can't sleep, so I go down in the garage and install a heat shield around the wiring harness to get past my insomnia. For some reason only the alcohol knows, right in the middle of installing the heat shield, I look aver at the radiator and in a demonstration of attention deficit, I popped the radiator cap and with a flashlight, looked at the coolant. It was night time so for the first time, I used a flashlight when looking at the fluid at the top of the neck of the radiator, and what do I see? I see some red tint in the radiator.
So I think, "hmm". I look in the overflow tank, its red. I think again, "hmm - so the dealer/PO goes to the trouble to install an expensive new radiator yet they used the wrong coolant and forgets to change out the fluid in the overflow resevoir?". So, I get a white rag and dip it in the radiator - the fluid is RED! For the next 20 minutes I am using all manner of lights, cloths and siphoning strategies and I get red fluid every time I take any out. Yet, it looks GREEN in the radiator under light??????! What the heck?
So moments ago, I go out in the fresh sunlight, pop the cap, I'm sober and just in case someone spiked my drink at work, I take an employee out with me and I ask him, "what color do you see?". He says green. I give him the flashlight and he then sees it as red! I dip a white cloth in and it comes out red?
Question #2 Anyone have any thoughts on this crazy thing?
Question #3 Can you point me to a thread or juist tell me where the block drain plug is?
Thanks for your help Team MUD!
Kirk
Kirk
From e9999's thread (https://forum.ih8mud.com/80-series-tech/14891-cleaned-my-cooling-system-full-scoop.html#post141441):
To find the block drain plug: separate a bit the middle and rear skirts in the wheelwell on the US DS. You will get a narrow slit. On the left is a vertical bracket supporting the shock. On the right is the rear most skirt. On top is a horizontal bracket. On the lower side are 2 hoses. All these frame a narrow vertical rectangular opening. If you look straight at the block through this opening you will see a lonesome bolt head on the vertical face of the block. That's it.
I had a mix of fluids in mine so some of the coolant looked green, some red, and some orange. Just flush it all out and replace with your Toyota red. Don't forget to open the heater valve first (slide the temperature control to hot with the key ON)
2 jugs is enough. The system capacity is 13.4L (14.2 US qts, 11.8 Imp. qts)
Yes, add two gallons red and then the remainder with distilled water and you'll be perfect. I think the total is around 14 quarts, and assuming you've also drained using the block plug you should be pretty much empty.
