Lower low range
After having a jeep with a 4:1 case I dont really want to off road with antthing much lower, even with the auto box.
Seeing as 80's have 2.7:1 (ish) what are the options for getting lower transfer case gearing?
Fj60 case with lower gears or doublers? can you keep the same shifter location?
Or is atlas the only viable way?
Discuss and suggest please.
Looks like too much money for a set of gears. How about swaps? whats been done?
atlas, mini truck, other LC's anyting that has been done for lower ratios.
Is re gearing enough for 35-37" tires to really crawl well?
If you read the threads I posted you would have found info on the Marks crawler box. Here is an install, should give you an idea of the issues with making a "crawler "out of an 80
https://forum.ih8mud.com/80-series-tech/163943-marks4wd-cruiser-crawler-install.html
Nothing is an easy swap. You need a T-case right side rear output (ie Orion or the LR 205) but they don't offer much more the stock OR swap rear end and move the gas tank to use another T-case (after making custom adaptors).
What is your idea of "really crawl well"? Many of us have done the Rubicon and other tough trails with nothing more than regearing the diffs. You are wheeling a school bus, IMO the sheer size of the rig is more of a limitation than the low range.
Actually, yes. The autos in this to a pretty good job at crawling. I'm running 5.29 gears with 35's and I'm just about ready to step up to 37's. I would love to have t-case gears eventually, but there really is no cost effective way to do it. For now I will just deal with holding the brakes on while keeping the RPMs up and watching my tranny temp.
I have an easy answer for you:
If you are ripping drivetrain parts out of an 80 you are modifying the wrong vehicle.
The entire value of an 80 is what you don't have to do to it. If you have to replace t-cases you really need to replace axles, and if you have to replace axles then you are only modifying an 80 a) to be different, and b) to chop the top in the relative near future.
3"-4" lift, 35" tires (37's if you really want 'me like me), 4.88's or 5.29's, and factory lockers will take you anywhere you need to go in an 80.
You will be amazed at how much you beat the crap out of the underside of an 80 with it's size and low hanging frame. Wheel it for awhile and see what you really want and need.
