Low RPM/Idle Issues
Bay Area
Slowly getting my 60 running smooth and have hit an issue others have faced but with a twist:
• Was having serious hesitation and almost stalling when the engine was cold and I would apply gas. This was only at low RPMs and as the engine warmed up it seemed to vanish.
Here's what I've done so far to address this:
• Rebuilt the carburetor
• New spark plugs
• About to install new spark plug wires
After the carb rebuild it runs MUCH better at high RPMs, lots more power, smoother more reliable acceleration.
The twist:
• After rebuilding the carburetor I realized the idle had been set around 900-1000 RPMs (this is what it was idling at before the rebuild). I went to correct this and found it runs VERY rough if not completely stalling out at idle below around 800 RPMs.
I've found threads here about checking the vacuum lines, EGR, manifold leak to try and solve the hesitation at low RPMs and plan on doing this. I'm curious if anyone has any suggestions about why it won't idle comfortably at less than 800 RPM and if the two could be connected.
Any help is greatly appreciated!
First thing first, you need to go through the FSM on the carb setup (see my signature line for links). You may not have the fuel screw (if exposed) turned out enough to supply fuel to the carb at lower RPMs. There is a section that details going through the "lean drop method" of adjusting the fuel mixture, idle speed, and timing to the proper specs to allow for adequate everything.
Other thing to realize is that you really should let the truck warm-up for a few minutes (5-10 for me at 4500+') before taking off. For my particular truck this serves two purposes; 1) it gets the oil warmed up and the truck to a nice idle, and 2) I find that my tranny shifts much better/nicer once the truck is warmed up. If I take off right away I have lots of hesitation and the shifting between gears is very notchy.
If you are going to run the truck right away after she fires up I have heard of guys that leave the choke pulled out a notch or two until they feel the engine has warmed up some.
Once you are sure that you have your timing, idle mixture and speed dialed in then I would move to finding leaks. BUT, if you have not personally replaced the vacuum lines and do not know the last time they were replaced you would be well advised to go through and replace ALL the vacuum lines.
LOTS and LOTS of knowledge and information on here so we should be able to get you dialed in...
Easy thing to check first: fuel cutoff solenoid.
Look on the top of the carb. There should be an electrical plug (I wanna say the OEM plug is green?). With the key turned to ignition (but the engine not running), see if the solenoid clicks when you unplug it and again when you plug it back in. If it does, there are very good odds you've eliminated it as a cause for your problems.
If it's not switching on and opening the solenoid when it's supposed to, it'll keep the carb from getting enough fuel to idle at regular, low RPMs, and it'll cause the problem you're describing (I had a very irritating afternoon, back in the day, trying to get my engine to idle after putting everything back together, just because I forgot to plug the solenoid back in).
If it's not working, there are a few things you'll need to do to figure out if it's the actual solenoid, or the wiring that's supposed to supply 12V to it, but don't worry about that until you've at least tested if it's clicking on and off.
Thanks for the advice. Figured out things were askew when I tried the lean drop method and couldn't get the RPMs low without the thing dying. Doesn't mean I didn't do it wrong but definitely idling rough at the moment. Probably going to go through the process again to make sure I did it correctly.
Otherwise yeah, no clue when the vacuum lines were last replaced so that will probably be my next weekend project.
I'm totally fine with letting the truck warm up, the big problem I've faced is when I'm in cold weather, below freezing, it won't sit at idle, even with the choke pulled and RPMs at around 1800.
I'll give this a check!
"Rebuilt carb" doesn't get you out of the woods. Who rebuilt it? What was done? Swapping in parts from a carb rebuild kit can still leave you with a sick carb.
