Also - you could break your diff, locker or birf....
Another reason not to put on your front locker while descending steep hills is that you could break something in your front axle.
The front axle and all of the components on most 4x4's is not as stout as the rear axle. Our FZJ80's are no different These trucks are designed for most of the power, torque, load, etc. to be transmitted from the engine, through the tranny, t-case, drive shafts, etc. to the rear axle. While climbing hills, accelerating fast, and towing, most of the vehicle weight and drivetrain stresses are shifted toward the rear of the vehicle. Not much weight or stress in on the front axle. This is why the rear axle in all trucks, including Landcruisers, is heavier and more stout.
Now, while descending hills, most of the vehicle's weight is shifted forward on the front axle. If the torque, stress or power on the front axle exceeds the strength of the front axle’s slightly weaker strength, you’re gonna break something. I believe this is even written in the standard owner’s manual in your glove box.
Not using the front locker is even discouraged while climbing. For most situations, locking our front diff locks should be a last resort. I know our 80’s are tough, but there’s no reason to press your luck. Being stuck in mud is one of those last resorts. In mud, your tires will slip before breaking something in the front axle.
While descending steep hills, better to leave your front diff open. You’ll be able to steer better, and you’re less likely to break something.
