Low Oil Level Light
I have a 94 LC. The low oil level light does not light up during the self test (turning ign key to "ON" position just before start). This indicates that there is a problem with the light. I had someone look at it, they determined that a circuit board (used for a 40 second delay in activating the light) located in the instrument cluster was the problem. I was able to locate another circuit board, however that did not correct the problem. Any other help is greatly appreciated. I really want a fully functional LC.
Trying to get to the bottom of this. My 1994 Land Cruiser "low oil" indicator light comes on after 30 seconds after starting the vehicle and stays on all the time. However the oil level is actually full as indicated by dipstick and after oil changes. Also oil pressure reads strong on the vehicle. I would like to hear if anyone has had this experience with there 80 series.
Anyone know where this low oil mechanism is on this vehicle?
Thank you.
The oil level sensor is on the drivers side just above the rear of pan if I remember correctly. If I remember correctly I was having the same issue as recruiser and found that the plug had a bad connection. PITA but simple and cheep.
Thanks to the help received this morning I have the following to report. Got under there found where the oil level sensor bolts onto the side of the motor but there was no wire harness attached to it. Reached up a little further and found the wiring harness just dangling and full of crud. Used brake cleaner to spray off the male and female portions of the wiring harness where they connect and using a mirror saw that the harness on the truck side was broken / mostly missing, but the two bare metal prongs were still intact sticking out of sending unit and buggered up pretty bad. I straightened out the two metal prongs (from what was left on the motor side of the harness connector sticking out of the sending unit) then stuck the female portion ( other end) of the wiring harness on to the to bare metal prongs. Pressed it on firmly as I could so that the metal prongs from the damaged connector fit snugly into their spots. I may need some JB Weld on the connector so it will stay on.
Road tested and problem solved! No more yellow/ orange low oil level light on the dash! Score!
