Hello Gents,
I need some help on a low idle problem. I’ve used search and read some posts, but I would like an opinion on which way to proceed. The tech at the dealership had no idea.
My cruiser always had that low idle occasional stumble. Over the summer I replaced the head gasket and now it runs @ 525rpm and keeps throwing a p0300 code.
The injectors were cleaned and calibrated, timing set per FSM.
I tested these parts,
Circuit open relay, OK
Fuel pump relay, OK
Resistor OK
IAC, OK, took it off cleaned the hole
TPC, OK
Fuel pressure reg, do they ever go bad?
MAF, OK
EGR , PCV, Air Hose have been replaced.
Vacuum at idle 17 inch (Dan told me to check that)
Did the carb cleaner spray to find leaks, double checked little vacuum hoses and cleaned
the fuel pump connection underneath by the back tire. I’ve checked the bundle of wires by the EGR by pushing on it and it did not effect the idle.(mine never really touched that pipe)
I have not been able to check the fuel pressure at the injector rail.(I know, go check it)
The cruiser accelerates nicely and runs well at speed, even when coasting at low speeds it seems to idle ok.
When I turn the ac on it brings the idle to @650- 700rpm and it runs smoothly.( it should be higher) How does turning the ac on bring the idle up?
[FONT="]Give me an idea on how to proceed, THANKS[/FONT]
97 FZJ 147k
Fuel pump relay, OK
Resistor OK
TPC, OK
MAF, OK
97 FZJ 147k
. I have checked the same items as you. hope someone smarter then I will answer.
