Low idle..
Clemmons, NC
I recently pickup a locked emerald green 94 fzj80, and have been fixing little things here and there. I've noticed it has a low idle once it warms up. So here is what I've already done.
Checked air intake hose for cracks, looks brand new, PO must have replaced it.
I replaced O2 sensors and cleared the code 25, and 26 that I was getting. They have not returned.
Ran seafoam through a full tank, and sucked it through a vacuum line.
Used 3m throttle body cleaner, without taking the throttle body off, I tried to clean it as best I could. Also, cleaned the MAF.
Just did a full tune up, denso cap, rotor, and plugs. NTK wires and Toyota air filter.
It's been about two weeks since I've disconnected power from the vehicle, so it should have had plenty of time to learn to idle again.
Here is the situation:
On cold start it will rev to 1800 or so, and as the engine warms up the idle slowly drops. When it gets to operating temperature, the idle drops to 400 rpm and shudders. Now if I put it in Drive/Reverse it will load the motor up, and slowly the idle climbs to 600 rpms, and will never drop below 600 again. Basically, ever time I start it up when it's cold, I'll have to go through this procedure in order for it idle correctly.
So my question is what is the next step?
Remove my throttle body and clean it? How easy is it to clean the IAC and is there any adjustment? I'm assuming it has something to do with the IAC circuit, is there any tests to confirm this theory? Thanks in advance guys! :beer:
idle
i had the same problem i replaced my idle air control and it came off idle around 750 to 800 after that. try testing yours according to the FSM. i had one circut open.
I just put an IAC on order, I'll test the motor tonight! Thanks for the help!
I will be interested in hearing if this works for you. I just had my head gasket replaced along with all the hoses, vacuum hoses, vacuum switch that resides under the head, blue flying saucer deal. Everything including the water pump, thermostat, gas regulator, fuel pump, valve grind, injector service, fuel filter, belts, rear main, Tps, throttle cable,rotor,cap,plugs, couple of pulleys, valves adjusted--I'm sure I am forgetting a few things. It runs better then it did but I still have the low idle. In park I sit at 6.5 but when in drive she drops to 5, or with the A/C 5.5. Now if I shift into park with the A/C she gets up to 8.5.
The parts should be in on Monday or Tues next week. I'll keep ya posted either way! I am almost 99% sure the IAC will fix this problem. now. Only bad thing is it's $321 dollars from the dealer :|
Just giving an update. I throughly cleaned the TB with the 3m cleaner and a toothbrush. Installed the new IAC with o-ring, along with a new TB gasket. She runs like a dream now, idle no less than 600RPM. Adjusted the kickdown cable (lubed it) and the cruiser runs better than ever! Worth every cent IMO. Cheers.:beer:
Some more observations after driving it for two days. It cured my startup rattle. It used to rev to 1800 rpm and drop back down slowly. Now with the new IAC it only revs to about 1500 and drops to 1100 rpm quickly. I'm running 10W-30 M1 with a napa gold filter. I'm all smiles.
Force - I am having the EXACT issue and I am new to all of this so I'll ask for your forgiveness ahead of time. How hard was the TB removal? How much was the IAC and what is it and where is it located? You may have just found for me the exact answer I have been looking for. Thanks ahead of time.
