Losing my mind
Brighton, Co
Bought a 92 fj80 last week. Immediately changed the upper radiator hose and what I’m guessing is some sort of coolant bypass(smaller diameter hose on the water thermostat housing in a u shape. And hooked up the stock temp gauge as it was disconnected by the previous owner. Onto the perplexing part...
After dropping bing it around smoke comes from the passenger side of the engine about where the air cleaner is. Oil is not milky but on the low side. No gunkyness in the oil fill. Coolant is still topped off.
Oil cooler leak? it's on the air filter side tucked under the exhaust manifold.
got ahead of myself>>>
what color smoke, what does it smell like?
Definitely not the exhaust manifold, wrong side of the engine. I'll check the oil cooler in the morning.as well as quintuple check that silly radiator bypass hose. In the snow AGAIN...YAY ME
I forgot the 92 has a different engine than my 97.
There are a number of coolant lines on the right side, if its smoke or steam, that will tell you a lot about what might be leaking.
