Loose steering
I had loose wheel bearing on steer axle and I wandered on rutted pavement and when stopping. Adjust the wheel bearings and its tight steering again.
Does not sound like your problem but it would make your problem worse if they were loose.
Did you try adjusting the adjusting nut on the gearbox? Have not herd of any luck with LC but it helped on my Toyota pickups.
I did try adjusting the box and it marginally helped but it's reached mechanical limits. I agree loose wheel bearings would make this worse and need to check for play all around. Prudent for sure.
@pnolanIH8MUD - I have very loose steering as well. What did you find to be your issue? I have not had the chance yet to check the wheel bearings or tie rod ends, since the engine has been in the shop being rebuilt, but I see myself attacking this sometime within the next two weeks, once I have the truck back and your experience may help me narrow down the prospects on mine.
Thanks.
Check the rag joint shaft coupler located below the dash. They always have some play, by design, but can get sloppy over time. Replaced mine a few years back and it made a noticeable improvement. Went OEM, was relatively cheap & easy. Maybe replace the firewall boot/seal thing while you're at it.
I am thinking that I'll have to look at any / all wear parts in the steering system. I have not started reading through the FSM yet, but anticipate
needing to replace several items, given the age. Thanks for the tip!
Worn tie rod ends will definitely contribute to sloppy steering as well. Cheap and relatively easy job with the proper tools. Tree fives (555) TREs are cheaper than OEM but every bit as good IMO.
Yeah, I anticipate a call to Cruiser Outfitters next week. :)
