Loose jam nut after alignment
Orange County, California
Just got my Lc back after alignment and one of the jam nuts on drag link is loose - freewheeling loose
I installed the drag link bar and tie rod bar myself - all slee with new oem ends on all. Put it into shop for some bushings and alignment.
Presume this is a something they definitely should have checked.....
Just wanted some feedback before I phone them back.
What's the torque spec on these jam nuts?
Don't think you can get a torque wrench on a jam nut so just cinch is down good and tight. I had to go to 3 different places before I found an alignment shop who'd touch my Budbuilt links with jam nuts. Did the shop give you a print out of the alignment numbers? If they're good then no need to go back or call them.
Answered the same in the other post.
Tight with a standard open end wrench. Since that will be a sizeable nut, then you should be able to get it REALLY tight with a straight combination wrench (or the 15" open-end adjustable metric wrench).
Yeah sorry about double post - alignment is good - just don't have a torque wrench that would fit on the jam so will have to wrench down - was thinking of just going back and getting them to do it - I live 2 blocks away...
Yeah, take it back, point it out, have'em fix their oops. Should take five minutes.
Tack weld.
It was a big apology - tightened up after rechecking alignment....
I'm sure this means something to someone!!
