Loose inner door handle fix!
Wanted to share a fix for the inner door handle on early front doors, and on ambulance doors.
These get loose over time from shutting the door with the handle instead of the door pull.
I used a cir clip 14mm to take up the slack. Pretty sure the photo will explain. I did have to massage it in place with a couple screwdrivers and a small hammer to tap it into place. Great fix without major disassembly of the unit.
While there get everything cleaned and lubed.
Hope this helps!
