Loose Driver Door Sil trim
Cleveland
The front of my drivers door trim is loose and floppy. Anyone have a link to instructions on how to remive it to see what needs fo be fixed?
There's a series of body clips and some 3M double sided tape that needs to be replaced for the cladding to be nice and toight again. Here's a picture of the location of the clips and which ones are needed:
Ebay and Amazon both have kits with all the clips you need or go with the OEM p/n provided in the image.
Thank you very much. To remove the cladding, do i just pull it (carefully) and the pins pop out? Any info on what double sided tape I should be getting/where it goes?
The clips will pop out of the cladding if you pull on the cladding itself. The clips will then rotate out if you attack them from within the door. The 3M tape I used was the standard automotive mounting tape you can get at any parts store. I had some on hand from previous projects and used that. I don't remember the width. You'll see where the 3M tape goes. A good cleaning/scrubbing of the tape mounting on the cladding will do wonders for adhesion.
Ordered the clips and finally got around to doing this. Pulled the trim panel and saw the clips were already in place just not snapped in. Pressesd the panel and snapped the clips in no problem. Haha i should have tried this a year ago.
i'm about to paint my GX and in the middle of removing parts to prep. This thread is very helpful for the part numbers for the clips.
I do also need to get the clips for the rear quarter panel and searching for those part numbers.
