Looking for Supercharger replacement hoses
Dallas, Texas
Well the man C-Dan advised me TRD no longer has the Supercharger hoses/couplers. Does anyone know of any place that offers them...I was hoping to find silicone hoses in Blue or Red. After 40,000 miles I guess it is time to replace them.
airlaird
airlaird
Ebay lists them in a variety of sizes. Samco hose is also available from a variety of turbo suppliers (try spearco intercoolers as well). I'm not convinced you need them as a RM procedure, replace them if they leak, but I'd bet all those elbows etc will run you a lot of money. For PM, get the equal load spring type hose clamps for the hoses you have, it's better money spent.
HTH
Scott Justusson
94 Supercharged
I'm not even sure anymore what the diameter of hose the s/c uses or what bends are there but www.turbohoses.com is a decently priced one-stop site for your hoses, clamps, etc. For what it's worth, the 90-deg bends typically come from the manufacturer with 10-inch "legs" so you can get one and usually get at least 6-inches off each side for any straight sections you'd need in the same diameter. Anything in the 2" - 3" diameter should only run $40-50 per 90-deg bend with the 10" legs. Anymore and you're getting fleeced a little.
airlaird said:
Scott...what the heck acronyms are "RM" and "PM"???
airlaird
RM = Routine Maintenance
PM = Preventive Maintenance
Pressure hoses operating at 6psi with a bypass valve (instant relief of pressure on throttle lift = vacuum) IME last almost forever. At 26psi it's tough to justify them as either RM or PM.
SJ
that was the site that came up on the google ad. did you get it from there or is that the best google ad match ever?
Adding some info to an old thread...
Spoke w TRD yesterday - as stated above, the no longer offer replacement super charger hose sections and 90's BUT they did say they were/are soruced to them by Flex Technologies in Torrance, CA. Their website is:
http://www.siliconehose.com/
If/when I get a response and some part number and pricing, I will post.
Phil H
San Jose, CA
'97 40th Anniv, TRD s/c, w stuff
