Looking for part number
Anchorage, AK
Can’t seem to find the right part number for the plugs on top of the rocker panels. I got this but doesn’t make sense to have something on top that traps water and dirt? Thanks
grab your pocket caliper , and let me know what the Exact ID or Inside dimension in Milometers of your Body through Holes are ........
- next , i will comb through my multiple totes with dividers , packed to gills exclusively with only OEM Toyota Hole plugs and grommets
see , i do not really refer to the entire Toyota body plugs and grommets by part # , i refer to them and organize them based on
only the sheet metal body hole size ID they are designed to properly pop into and secure fit .........
any time i take in a new toyota part # , i use a special caliper to gauge its intended body through hole .............
so you tell me 19mm ID in the sheet metal for example , i hand you a 19mm size spec plug , in your case a smooth top blanking type profile
let me know if i can further help , i keep plenty of in-stock on-hand inventory , so i will have you hooked up i no time
i have no less the 500+ part #'s on hand right now :)
matt
ok based on your pics above you have Un-desirable 90950-01826 , due to its recessed cavities that will trap dirt and water etc ........
90950-01826 is a 15mm body hole plug
we have a sweet sweet size spec. match that meets your new spec. , its thick heavy duty and has a smooth flat top , hence a blanking grommet ............
15mm hole plug grommet too
your new replacement part # will be 90950-01311
please review photos below
