looking for opinions about this wheel on my 80
I originally wanted to run the 16" Bronze TRD TT fake beadlock wheels but searching the 80 tech forum tells me the center caps won't fit without spacers. So I found these wheels which are the perfect size (16x9 -11mm offset or 16x8 0 offset) but I wanted to get some opinions on them.
Just make sure the center bore is big enough to fit over the Landcruiser hub. Most wheels arent bored big enough so be careful. Also becasue youll be going from a shank style lug to a conical seat, the lug wont grab as much wheel stud which over time will snap them off. Ask me how I know all of this ;):o
If they will fit, I like the 9 inch width for the larger tires. It is more appropriate for the bigger tires. I also run a 9" wide and like how it fills up the fenderwell.
I think when you have a vehicle that is silver, the greys and blacks look good in the mix.
Bottom line, a dozen people will give you a dozen opinions on the "look". If you like them, roll with them!
I checked and they are a 108mm center bore(didnt trust kmc's website). I also mainly like that theyre wider with a negative offset. Just have to find a buyer for my stock wheels/center caps/lugs and ill put an order in. Thanks for the input.
