Looking for an 80
SW Michigan
looking to replace my 60 with an 80 series from outside the rust belt. not ready to buy yet and if its your rig I probably can't afford it.
what should I be concerned (besides normal used car stuff) with on a 93 - 96 80 series I can pick up with 140K - 180K for 4000 to 5000 dollars?
not concerned with mpg, just reliability and potential problems i will need to be aware of and how bullet proof is the transmission?
Take a look at the "Thinking of Buying an 80? - Follow this link to helpful advice" link at the top of the 80 series page. It will cover what to look for and differences between FZJ80s and LX450s as well as differences between 93-94 & 95-97 FZJ80s.
yeah i read all that. very informative. its what convinced me to buy an 80. but i am looking to buy outside the rust belt and i have seen them anywhere from 3000 dollars on up to 6000 for a stock 80. what i want to know is what to look for considering I am going to have to drive it 2000 miles home after I buy it.
Good Luck. I am in central IL, and I settled for the one with the least amount of rust possible. I was pretty lucky I think. I only have one spot that has some rust other then that it is clean. I may be interested in getting rid of it if the price is right. PM if you are interested.
If you seen the frame on my 60 you would know why I want a rust free one.
1982 FJ60 - $2000
wiper motor and links - $538
new clutch - $586
labor - $538
look on my face when I realized 2 of the cross members rusted out ........ priceless.
Hey Ugly,
I understand your dilemna, rust is the enemy on the early LC's. The FZJ80 series had quite a bit more rust protection than earlier ones but still suffered in some area's of the body.
There are some nice low-rust ones from So. California to Texas I'm sure. I'd get very familiar with Craig's list or other sources for those areas. It's definitely a buyers market for these now. Your price range is not unreasonable but be expecting a little higher miler's for that.
Good luck. Dan.
yeah, thats what i have been seeing and i expect to have to do things like install locker or fix ones that don't work. all that is fine because I realize my price range is rather low but I got 3 kids in private school and replacing my Wife's minivan with a 4Runner right now is of the upmost importance, not going to leave me alot for an 80.
I have been looking on autotrader.com and Vehix.com and only looking at ones from texas to so.cal and eastern washington ......... buy one in washington and may have an excuse to see the in-laws ....... may even get them to pay for the plane ticket.
but like I said, can't buy until I get my tax return.
I lived in Eastern Washington and they use some sort of magnesium compound on the roads which is supposed to be just as bad if not worse than salt. I'd stick to the SW.
I see them forsale everyday in Florida. I would drive most of them cross country without a 2nd thought. Most of them are mall cruisers.
Lately I have a couple in the South East that are already built. More in the $5000 to $10000 price range, but it comes out cheaper if you are going to outfit it yourself. Unless you find a crazy deal on one.
Priced pretty high for my taste, but just one example.
1996 Toyota Land Cruiser FZJ80
ugly,
the transmission is not a problem at all. i've seen very few reports of transmission problems on the 80s.
however, there's paranoia over the head gasket on the 93-97 models to the point that some people replace the hg as pm. this is probably the most feared repair/problem on these model years.
recently, i've noticed problem reports with the cel coming on due to emission problems (most likely O2 sensors PO420, or egr valve PO401, or egr excessive flow PO402). maybe i've noticed because i have the PO420 problem myself. afaik nothing out of the ordinary and other manufacturers also have these emission problems.
As already mentioned, the trannys are rarely a problem unless they were abused or run low on ATF.
Cooling system needs to be in good condition before you head out on a 2000 mile return trip.
Other maintenance that you should consider (depending on maint records...) is:
Change fluids (oil, coolant, PS, tranny, diffs, brake)
Lube drive shaft unis and slip joint.
Check brake pads
Check front axle (add moly via knuckle plug if needed)
Check front knuckle studs
Check belts (if cogged or cracked, replace with new Toyota belts)
Check hoses (especially the PHH above the starter)
Check battery connections
Check tyres. If significantly different sizes then resolve this before return trip.
Check wheel bearings for excessive play.
Check lug nuts.
That is all I can think of.
-B-
In that price range it may not have had great service, so the front axle may be weeping a mixture of moly and gear oil because it's in need of a rebuild, but it should survive the trip home. You might want to see if somebody local can run a bubble check and sniff the exhaust to make sure the HG hasn't already gone, since you need to drive a significant mileage with it.
I bought in rust-free areas, and each cruiser has been a pleasure to work on. Good luck with your search!
I've got a '92 FJ80 that I'll be looking to sell (and I'm in So Cal) - it is a clean, tight rig, but I need to replace the engine. Was planning to have a low-mileage Japanese engine put in, but if you want it without the engine (to do your own rebuild), I'm sure we could work a good deal. It looks great - very clean - no rust. I'll post some pics when I get a chance....
I have to talk to my wife about that, she has already warned me about another project that sits in the driveway waiting for me to do something with ...... ie ....... 91 Suburban with a dead transmission I have been waiting for time to pull it, now with winter coming I won't get to it till spring and its been sitting for 2 years. I bought my 60 so I could work on the suburban and we wouldn't be down to one car while I was doing it........ now I am thinking the 60's engine bay would be a good home for the 350 from the suburban if the frame wasn't so bad off, thinking I could just cut down the suburban frame and put the 60 body on it. I bought my Suburban in Spokane so it has absolutely no rust on it. the paint on the frame is still shiney in spots. end ramble
If you're interested, I could have the new (low-mileage) engine installed so it is "done" - then we could talk price....how's that sound?
Please take this to PM.
-B-
