Looking for advice ref. 75 FJ40
Alaska
I have just purchased a nearly stock 75 with 64k miles on the odometer, this is my first FJ40. It is currently not running and I was told is an electrical problem.
It has a 2f motor with a weber carb and headers, no smog pump and what looks to be an after market distributor. I am attempting to get the motor running. I may have a severe wiring problem on my hands. Should I keep the 2f motor or look for other options? Is there an advantage to V8 and keeping a head of wiring problems?
Wiring to get the motor running is fairly simple. Only a few of them to hook up. I suck at wiring and I was able to get power to the things I needed pretty quickly.
I would keep the 2F if its already in there.
I need to learn from my own rules. If its not broke dont fawk with it.
There is really no reason for me to get rid of the 2f engine. I am attempting to get power through the wiring harness without much luck. As you advise I am going to have to bypass everything.
The only thing that I got from the prior owner was that he was attempt to charge the battery and had crossed the pos/neg for several hours and found his mistake when he attempted to start the motor with the charger connected. That was 18months ago and this 75 has sat since. I have change the fluids, which all looked and smelled clear and clean. Just need to over come the lack of power, I may need to replace or rebuild the started.??
Just Start Tracing out the wires and look for any fried wires. Obviously start with a fresh battery. Post up a picture of the distributor or the name on it. For a 1975 if it is stock it will be a points style distributor.
If you have not already get a wiring diagram and check off and label the wires as you find them, saves a lot of back tracking.
Shoot me your email address and I can send you some pictures of the engine compartment of a 1976 that I used for reference when I had to trace my wiring out.
Dave
Don't start changing parts without doing some investigating/diagnosing.
If it's true as the previous owner described he may have cooked something simple like a fusible link? Very basically, all you need is juice from the ign switch to the solenoid and coil at start and from the same place to the coil for running.
You'll need a testlight, a wiring diagram, and some logical thinking. Or you need some on-site help from a friend who knows about automotive electrical ststems.
It sounds like it's an easy fix.
pictures
Thanks all for the advice. Below are some pictures of the 75 cruiser. Sorry for the poor picture quality. As you can see we are getting lots of snow...
Do you get power to the starter, or not? Does it turn over?
No, there is no power to the starter. There is a wire attached to the positive lead going to the starter that is burned through.
Also, there is another wire burned through near the coil.
Still attempting to track down the problem.
Dave, what is this battery thing you speak of :rolleyes:
I'm an earlier cruiser guy, but the basics are basically the same for these rigs, and I have the 75 diagram in front of me. So, I'll give you a place to "start".
First, the wire off of the positive lead that goes from the battery to the battery post on the starter that is burned through is probably a "fusable link" (see recent post for discussion). It probably burned through because you have a grounding problem in the circuitry that caused too much current to flow, and it blew that wire fuse that is the link. Unfortunately, all that snow isn't helping the problem.
I would, until you sort that out, avoid hooking everything back up the way it stands, because the problem is likely still there.
However, you can do a simple circuit to test your starter, and to see if your motor turns over when the starter is powered. I do this (and most mechanics do, I believe) to test the starter, check compression, etc. where I don't want to actually start the engine.
Get a simple on/off push button switch for a couple of bucks at NAPA, and some 10 gauge insulated wire and two alligator clips. Cut a couple of lengths of the wire, maybe 18-24 inches. Attach one end of each wire to one terminal of the switch, and the alligator clips to the other end of each of the wires. Attach your battery pos lead to the pos post on the starter, and one of the alligator clips to it as well.
There is another terminal on the starter, one that accepts a spade connector. It may (if it is still wired correctly) have a black wire with a white stripe connected to it. Pull off that wire if it is there, and attach your other alligator clip to that terminal.
Your battery neg cable is attached to the frame, right?
Now press the switch button. Your starter should work and your motor turn over if both of those are OK.
I find this little device very helpful in testing out various electrical devices in my rigs.
The burned wire off of your coil is probably the black wire with a yellow stripe that goe from the coil to the ignition switch (with branches into the fuse box). This is the place to start looking for your short.
Get the rig inside where you can work on it. (and where it won't rust). Get some "exhaust hose" like mechanics use; rubber hose you hook to the exhaust pipe and run it outside under a cracked garage door so you can run the engine in a garage. Still run it briefly because crankcase fumes, etc will still build up inside. Get a simple test light at any auto parts store to test circuits and fuses. Should not take much to get this clean rig going. Also a cheap battery/alternator tester at radio shack or auto parts store is handy now and in the future. Get it going, then get some snow chains.
DocB said:
Get the rig inside where you can work on it. (and where it won't rust). ......................... Get it going, then get some snow chains.
He shouldn't have to worry about rust in the North Country until spring thaw :D
Sooner or later you're going to be told that your bezel is upside down.
Ignore the ignoramus who tells you that. :)
