Looking for a bolt
Hi all been a lerker for a couple of years. I have an m-416. I did a spring over and broke a bolt in the spring pack at the fron of the trailer. I would like to pick up two of them, if anyone has them laying around. Or does any one know where to purchase a pair online?
teaser;
I did buy at a hardware store only grade 5, as I am looking to replace the oricinal bolt that is greaseable. I am glad to see the response.
I figured that with all the guys doing indendant suspensions, they maigh have left overs. THis is the bolt that holds the front of the spring pacdk in the spring mount on the trailer frame.
I did a SOA and got 5 inches, then with the new tires wen from 29's to 33.3 BFG's what a difference. This amounts to about 7 inches of lift. Redoing the brakes on the trailer has worked out pretty well. Little bit of steel and all is good to go.
I will check out some of these sites and see what I can figure out. I will also consult the m-416 manual and get a part number.
OK.... SO...
From the parts manual pg 203, I need the following part #18 as listed;
18 PAOZZ 19207 7328328 BOLT,INTERNALLY REL SPRING 2
I am also emailing Midwest Military.
thanks all
