Looking at purchasing this "97 However...
I am currently in the market for a 2nd 80 and would prefer to get a '97 like our LX450.
Found a really nice candidate with 160k, I have found a few probs, hoping for some expert advice from you fine members!!
Problems:
Oil leak - I cannot tell where it is coming from the owner has never ever cleaned this motor. Looks like it leaks on both sides. One leak goes to the back of the power steering pump, so I originally thought it could be power steering leak however it didn't smell like power steering fluid at all.
The other side (passenger) has the side of the engine fairly caked with oil and looks like it could be the valve cover gasket leaking to me. My worry is that I can't see if the head gasket is leaking at all?? What can I do to really tell?
Would the head gasket leak anti freeze or oil?
Is the valve cover leak a major dealio?
Center Diff lock:
Can't get the indicator lights to come on for the Center diff lock or the ABS. I am assuming this system hasn't been excersised at all and could just need some coaxing. I have read several threads on this problem, and it could be a relay or frozen actuator but it isn't the indicator lights. If the center diff light wasn't working but the system was working wouldn't the ABS light come on regardless?
The vehicle is in good shape - front axle seals are good to go, no rust, engine runs smooth but I am getting belt noise kind of a higher pitch whine - these have cogged belts which I know are supposed to be smooth, does the belt cause that noise or the tensioner pulleys?
Would love some know how, I am limited with my experience with these? We have only owned the LX450 for about a month.
Just need to know what you guys recommend, I am in dire need of a vehicle and kind of need to make a quick prognosis and decision!
Thanks guys!
pics will help... if the HG is leaking that bad, I dont think the truck would run. I think it would be a mix of oil and coolant. search for HG symptoms like bubbles in the overflow, stuff like that (search, tons of info)
mine had a leaking valve cover and was quite messy w/ oil when I bought it. it is not a big deal to change. That doesn't mean yours is the same tho.
... I am getting belt noise kind of a higher pitch whine - these have cogged belts which I know are supposed to be smooth, does the belt cause that noise or the tensioner pulleys?
Cogged belts on the 80 will cause a loud whining noise. You should use only the Toyota belts. Tensioners (A/C and Alt) may be noisy but I can promise that the cogged belts are a problem. If the problem persists after replacing the belts then put a mechanic's stethoscope or a wooden dowel on the tensioner and see if that is the source of the noise. Replacing tensioners is relatively easy.
-B-
Ask a dealer what it would cost to replace all the engine gaskets (valve cover gasket, the oil cooler gasket, the oil pan gasket, the timing cover; maybe $1400) and repair the CDL and ABS (too much), then deduct that from the asking price. Should take a few thousand off, at least. Then when you get it home, carefully clean off the engine (method of your choice), and watch the leaks. Sounds like valve cover if up high on the passenger side, oil cooler if down low on that side. The driver side oil "leaks" behind the power steering pump could just be messy oil changes done at WalMart. Make sure there is no oil in the coolant reservoir tank, check the radiator also. Check the oil dipstick and fill cap for any signs of water. Ask the owner specifically about the headgasket and other leaks; has he ever added any sealers? He could just be clueless, or he could have just been told it needs $5000 worth of repairs and he is dumping it while it is still running. If you know where it's been serviced you could give them a call. X20 on the belts, of course, the noise from them could be hiding other noises/squeaks. If you can spray water on the belts (like from a garden hose) while it's running, and the noise goes away for a few seconds, then comes right back, then it is the belts. Just stand back when you do that.;) This shade-tree test also gives you a chance to listen for other noises during that moment of silence, if it comes.
Good luck.
