Longs?
So I'm wondering a few things about the 80.
I know the birfs are larger than the mini's and 40/60's.
I have a pretty built 40 on 37's that has the 30 spline longs already for the more extreme stuff.
My wife has a new to us 80 and I want some input. It has 37's on it, Slee part time kit and Aussie for the rear. I just ordered 5.29's for it (stock gears for now) and another Aussie for the front.
This rig is basically a mommy missile for the wife and kids to come play in on the trails with me. It won't see too much in the way of rocks, mostly milder trails/snow and the Rubicon/Moab this next summer.
Would it be wise to step up to Longs right now? The tires are Toyo M/T's on steel wheels. Going to upgrade to some new BFG KM2's and creeper locks but it might not happen before the longer trips to the Rubi and Moab. So I will still have the heavier wheel/tire combo.
Advice?
That is what I was thinking as well. Maybe safe than sorry? I like peace of mind.
Just my web opinion, but I'm not sure how much I'd like the idea of an auto-locker up front with my wife and kids riding icy/snowy roads to get to the trail. I suppose the part time kit will help if you leave it in 2wd with unlocked hubs on road, but....
Well....we don't get much snow-ice down here. But thanks for the concern.
Jason, I would also hesitate to put the front locker in... You really aren't going to need it for what you are planning on doing with it. However, if you do decide to lock up the front, I would upgrade to Longs and Marlin's inner axle seals. The one downside to doing that (other than cost) is the AVS hubs you are running will void the warrenty on the Longs if that hub breaks. Again, I don't think you will be wheeling hard enough for it to be an issue, but you have to run Bobby's CM hub gear in an Aisin hub for the warrenty to be valid. The problem is Aisins don't fit with the long style birfs (which is what you have in that truck... They are my old birfs in it). I am planning on having a spacer that goes behind the hub to make them work, but I have some playing to do with it before it is ready...
Sorry, I guess I mis-read the original post where you wrote it will see snow. :confused::flipoff2:
If the snow only occurs on the trails, I guess you won't be using 4WD on-road.
Are you taking about the longfield brifs? I am no expert but I looked in to this for my truck as well. I put the Poly Axles in but the Lonfield Birfs. After doing some research, I found out they wear much faster than the OEM birfs. Rumor has it 15k miles or so....but I am no expert nor do I have first hand experience....I just spoke with poeple who do.
Yeah, he's in the valley... As soon as there is an inch of snow on the ground, everything shuts down!
Great points.
After reading about the issues with putting in the longs with the AVS hubs...and the machine work required, it doesn't seem like a good idea right now. Maybe if this rig was a main wheeler, but I think Chad might be right about what the rig is going to do and how it will be used. Maybe a front locker is not the best choice right now. Or...maybe I just need another ARB. :D
Yes, the snow is on the trails only. We get one or two weeks a year down here that have small dusting on the ground. Not like anything in Canada!:eek:
